Suspension and Lift to fit 35" Tires on a VDJ79 Double Cab
Hi Guys
Im looking at doing the suspension lift and replacing the tires on the VDJ79. Note this is the model with the Toyota factory tray (wellback)
What I'm looking for:
Fit 34-35" tires (315/75R16 ideally I know the diameter changes with brands)
Minimum lift possible to keep centre of gravity low and prevent scrubbing
Get the more flex out of the suspension.
I live in Sri Lanka hence difficult to keep trying different setups as imports have been restricted and freight is crazy expensive.
I know this tire size is a common fit in Australia hence appreciate any advise on a good setup.
Regs
CL
With a true 35" tire or even a 34" tire you will have issues scrubbing the inner guard when flexing and turning with a 2" lift. Since anything over 2" requires radius arms, and springs are cheap I'd suggest a 4" lift for you. It in my experience a 4" lift doesn't make it feel a heap more tippy off road, anything more than that does. If you want the middle ground go 3".
Check out some of the 70 Facebook groups , there is most likely a lot more knowledge there than here. Post up what ever you decide on doing and end result for those of us that can’t have a vdj79
Thanks will post on FB
Thanks
I just bought a RHD 2007 single cab V8 turbo diesel with 315/75R16 tyres and (although I have no way of confirming it without another vehicle to measure against) I don't think mine has much lift - if it has any. It's certainly closer to the ground that my 2 inch lifted 105 series... but does have heavy duty aftermarket springs for carrying big loads (which are awful
tbh)
You can check out my thread for a 4" lift, radius arms, and 35" tires. Though IF you can find a 3" lift, you could try to go with that. I get a bit of rub turning full one direction on the frame, but with a narrower tire, you may avoid that. I will be trying some wheel spacers in the spring and see if that looks after the wheel rub. I used a mishmash of OME, dobinsons, and terrain tamer parts.
