Well, I took the day off from work & finally got around to my LC "to do" list, triggered by CE P0155 (Bank 2 O2 sensor 1). I figured while I'm at it I'd also clean the throttle body, MAF sensor, and drop in a TRD air filter. Running boards off too; might as well as long as the compressor is fired up.
Thoughts: 1) I love the new look, sans boards...my LC no longer looks like a cabin cruiser. 2) Only difficulty I ran into at any time was getting the connector free from the harness on the bad O2 sensor; fought tooth & nail with it, from underneath and from through the wheel well, until I finally won. PITA. 3) Couldn't believe the amount of carbon buildup there was in the TB; STP, a toothbrush, rags, and elbow grease prevailed in the end. 4) MAF sensor looked fine, but cleaned it with CRC while I was in there. 5) Dropped in the TRD; my paper filter was dirtier than I thought-- hadn't checked it in a very long time
When finished, reconnect the battery & started it up-- as expected, idled high (~1200) for a few minutes before tapering down to ~700. Just got back from a test drive; it is smoother and more responsive...not an enormous thing, but enough to notice a difference. Very happy with the results, especially since...
Resetting the ECU has definitely improved the shift characteristics of the tranny! I suppose the TCU reset as well (logically) and now that little bit of rubbery slop I used to have between shifts is history-- shifts are much crisper and seem better timed than before. Unexpected bonus that I'm quite happy about.
Moral of the story: if your tranny shifts aren't to your liking, try disconnecting the negative battery cable for a little while...seems to have worked for mine. And if you're putting off cleaning your TB, call in sick & do it
