SUN ROOF GASKET REPLACEMENT
SHERMAN FJ62
Charlestons' King of Cruisers
charleston
I HAVE A LEAK COMING IN ON MY SUNROOF. LIVE IN THE SOUTH SO THE GASKET HAS SEEN HARD SUMMER HEAT. I THINK THAT I NEED TO REPLACE THE SEAL/GASKET AROUND THE SUNROOF. ANYONE DONE THIS REPAIR IT IS HARD? ANY ISSUES?
THANKS
The sunroofs leak, they all sort of do, by design. They aren't made to be air-tight, just mostly so. Some water gets by the seal around the edge of the glass panel all the time.
There are channels all the way around the inside of the opening to catches water that leaks in and move it to the sunroof drains and out. You most likely have a blocked sunroof drain.
