This may be the forum's dumbest question but can someone explain to me why I cannot establish a 12 volt supply for accessories by simply making a circuit from one of the two batteries, independent of the rest of the vehicle's 24 volt system?
More clearly, couldn't I use one of the painless fuseblocks, wiring it's input directly to one battery for both pos and neg connections, and then use it's output circuits as a 12 volt supply with no further ado?
As some of you know, the BJ40 which I bought from Wayne had large connectors in the bib that were for supplying electricity to start airplanes or something. One of those was a 24 volt output, the other a 12 volt output. I've removed both and in doing that I noticed that they were each wired very simply. The 12 volt one had it's positive connection at the RH battery with it's ground being the common ground to the frame under that same battery. That's all there was - no converter, nothing but heavy wire and simple connections. So why can't I reestablish that 12 volt output on a smaller scale and never bother with a voltage converter at all?
