Stuck rod bearing cap (1 Viewer)
Rock the crank back and forth some or tap with a rubber/plastic/brass mallet. You might also try turning it BDC on that cylinder and tapping the rod studs with a plastic or rubber mallet to push the rod upwards away from the cap. If you try that, don't use a brass mallet.
