hi, I'm new to these forums but not 4 wheeling or Toyota's, I have a LJ70 waiting for some serious modifications, but before that I have another question I hope someone can answer.
The rig I use for trials here in the UK has a Subaru engine, flywheel and clutch pressure plate mounted onto a Daihatsu gearbox and then to Range Rover axles.
The only friction plate I could find that mated it all up was from an old Toyota Celica ( mid 80's rear wheel drive ) but I've ripped the centre out of it.
I know that Yota made a lot of clutchs with the same dimensions -
224mm ( 9 inch ) outside dia. 21 splines. Inside dia spline 25mm ( 1 inch ) outside dia spline 28.7mm ( 1 1/8 inch )
My guess is that somewhere there's a solid centre clutch plate that is fitted to a pickup or small cruiser of the same dimensions.
The Daihatsu friction plate wont fit as it too big dia, although the splines are the same as Yota. I can't fit a bigger pressure plate because the Subaru flywheel is recessed!
The parts guys over here can't help me unless I have some idea of what model and year, and hopefully engine type etc to order a plate, nobody carries stock anymore so I can't find anywhere to go and look even.
If I can't find a stronger oem friction plate then I'll have to go for a competition plate, possibly a paddle.
Has anyone any experience of these, or even better any idea which Toyota oem plate is strongest?
thanks
Dave
thanks
Dave
