there has to be a short somewhere and I agree with the above, call the home inspector and tell him he's paying for a licensed electrician to come out and find the problem since he obviously didn't.
One wire that goes to the kitchen above the stove (microwave), and one to the doorbell transformer on the side of the panel. Both those circuits run neutral to the ground bar. One wire on breaker 24.Are there 2 wires landed on breaker 13? Can't tell from pic.....
it has to have a disconnect, usually a main breaker in that panel.
NEC 230.70
If this is the same specter that signed off on this debacle, then he don't got any legs to stand on when it comes to your unpermitted circuit. And I'd tell him that too if he says anything. This is his(the counties) bad.....
Weak. Working on your own s*** is the manly way, knowing your limits is smart. I've worked however briefly as an electrician, and I'm calling in the pros now after consulting with the mud electricians just in case I'm not seeing something obvious. And a "reasonably low amount of money" is over $100/hour plus callout and many other charges. I don't like paying for things that are obvious and easy, and I like doing things myself when I can.
I draw the line with electricity and plumbing....
did they already have the home inspection? I'd be calling that guy if that's the case, many places offer warranties on repairs if they missed it.
Really?
My Dad was not a good plumber or electrician, so he made sure I learned those trades from Lt. Dan who worked as a plumber and electrician. I have wired a s*** ton of houses and shops.
I've also laid more pipe than most men
I'm with you, Scott. Who gives a s*** if your daughter's house burns to the ground while she sleeps when you may have to pay up to $400 to fix the wiring? I mean, that's a lot of money, and doesn't even cover all of the other charges which could push the bill all the way up to five or six hundred.
Good to know, thanks, I'm not sure on all the legalities. This would be a difficult thing to detect, so I have a hard time saying he didn't do his job, but it did happen under his watch so I can see him being responsible.
Really?
