the gimpey one said:HAAAAAAAAMMMMMMMoooooooommmmmmmm!!!!!!!!!
the gimpey one said:so is the imspection cover the big flat thing that looks like an oil pan? Will it rain oil when removed?
the gimpey one said:this is where i saw the water seeping/leaking from
so today i make a short run to ace hardware which is less that 2miles from my house. Get out of the truck and hear something gushing!! Guess what pic #3 is??? The water pump seal!!!! So now my water pump must be pulled and replaced!!!![]()
That water is probably coolant coming from above. You need to find the source which could be your water pump or a hose.
Most definitely find the source first. It might be worthwhile to rent a hot water pressure washer and get that grime off so you can diagnose it. Whoever you get to look at it for you will be much more willing to help with a cleaner slate.
Jeremy
