Your front pressures are high, you need to adjust your torsion bars to lower those pressures. Tighten the 30mm bolts on the rear of each torsion bar, start with 2-3 turns on each and check your neutral pressures again after going for a short drive.
Your rear pressures are a little high but not bad. Rear spring spacers will lower that pressure around .4 mpa.
With no front bumper you're better off staying with the LX torsion bars.
I'm running the Dissent front bumper with a Smittybilt x20 12k winch and 2" front lift. My LX torsion bars were easily adjusted to get good static pressure readings. The LX bars are not strong enough to handle all of that weight dynamically, while driving, I get a lot of dipping in the front when slowing/stopping and the AHC constantly having to re-level the front. I have a set of LC torsion bars now and will be installing them soon. Sadly this system is too intricate to simply throw them on and dial in static pressures to FSM spec on the heavier bars. It's going to take some adjusting, driving, monitoring, adjusting to get a pressure that the AHC likes while still maintaining the good soft ride that I had before beginning to mess with things on the truck.
The rear 100 series springs are the stiffest of the OEM rear springs and will be too stiff even with a rear bumper.
Rear springs in order from lightest to heaviest are: OEM LX, King Springs, 80 Series LC/LX (there are multiple versions of these each with slightly different spring rates), 100 series LC.
I tried the 80 series rears with sliders, Gamiviti roof rack and 3" of sensor lift. They were way too strong still. With the same accessories, 2" of lift and new OEM LX springs with 30mm spacers my pressures are still high but I have no issues going into H mode.
Once I finalize my drawer system and install a Dissent rear bumper I will revisit the 80 series springs. If that doesn't work out I will drop down to the King Springs and if needed trim packers/spacers.
