- Joined
- Nov 22, 2010
- Threads
- 44
- Messages
- 2,151
- Location
- Wilmington, NC
- Website
- www.kindredspiritscsg.com
- Thread starter
- #141
One thing for sure to check when getting a new axle is the lug spacing. Turns out Chevy/GMC went to a 8x180 spacing in 2011. This means that the axle flanges are different too from older model trucks. There isn't much information on this so I will continue to post any other changes I find.
In the meantime, I needed to swap it back to an 8x170 pattern. Easiest way is adapters, but tacking on 4" to an already wider axle was a no-go.
One of the main reasons why I wanted to run a 14 bolt in the first place, other than the 3rd pinion bearing, was the fact that they are super easy to work on and can be chopped down to run "two short shafts". This would shorten the axle down 6", allow me to bring a single spare, and allow me to run adapters, to keep the same axle width.
I got to make good use of the metal chop saw I picked up. Hands down one of the best purchases I have made. It chops through steel like butter, no heat buildup and clean edge ready to weld up. Made quick work of that axle tube.
Clamped back up and ready to weld.
Welded up!
Since I had an extra "long shaft" I decided to make a trail spare. Probably wouldn't last under some significant abuse but I imagine it would at least allow me to limp off a trail.
Welded up!
