Stereo quit working but other functions fine (1 Viewer)
CloudCity
LuxCruisers
Palm Springs, CA
I'm not able to hear any music from my stereo (CD/Cassette/AM/FM/AUX) and only hear a repetitive light pop sound coming from my speakers. It sounds almost exactly like the end of a vinyl record how it just keeps popping after the song ends. It does this if the audio system is on or off. This is the Mark Levinson system on my '04 LX 470.
I can see all functions on my screen fine, and when switching between the CD, tape, and stereo they look like they're working with tracks counting, volume indicator showing, etc., just no actual music comes out. My climate nav, etc., all works fine.
I have the Grom setup that's an AUX-in only, no head modifications and have had this for several years. I can't switch to the AUX by hitting the disc button however, so unsure if this is somehow a Grom issue or a head unit issue. Is it the amp?
If have a way to easily do it I would check your battery. I had this happen a few years ago and the next morning it wouldn’t start. Replaced the battery and everything worked fine and no problems since. However, I can’t remember if I had the popping sound you describe.
If it's the amp, check out modulemechanics.com, they might be able to help. No affiliation, but they do have a lot of vehicle electronics.
Thank you all, I did check my battery and it's only at 12v instead of 14v where they like to sit so may start there. Have been doing some short sporadic drives lately so might even start with a long cruise, and replace it if needed.
I tried to check for any codes in case the amp would show one, but my code reader is wifi and not connecting. Will get codes read. I know there's amp posts so I will see what some other signs of a failing amp is.
I did check that suggested website but they only had keys for the LX.
Appreciate all the help so far!
