Have you checked your steering links at either end of the steering rod? I had similar problem with my 79 series pick up. Felt like the steering wheel was going to break off.
Remove the split pin, plug and spring. Clean and reassemble, tighten plug and slack off half a turn closest to split pin hole. Refit split pin.
Drivers side, in my case RHD, can be done without removing wheel, passenger side you have to remove wheel.
