Hey guys, just recently swapped my 06 LX steering shafts over to the LC equivalent while changing steering rack. Did this to get rid of the pesky VGRS system, as the ECU has presumably been bad for years and I have had a tilty steering wheel. Mechanically everything bolts up and I have a straight steering wheel now. But I'm having a small issue. The connector between the upper and intermediate shaft did have to be slid upwards in space (towards steering wheel) as the relative lengths of the two shafts are different between VGRS and non-VGRS. The upper shaft is shorter and lower one is longer now. The upper bolt on the connector is making a little bit of contact on the firewall tube in certain positions and I can see the intermediate shaft moving a little bit when I turn the wheel. Not possible to slide the connector more than a few mm.
Am I missing some sort of centering sleeve or support? Any advice here?
