Hey all,
I am trying to remove the steering column shaft from the firewall to the gear box. It is not fully clear to me how it comes out. I was planning to leave the steering box and steering wheel in place.
My FSM does not really show it clearly.
I removed a bolt at the upper spline to u-joint and at the bottom where the u-joint meets the steering box. I also slide the rubber boot up and can see a nice clean spline on the shaft with a some sort of collar.
I decided to pull the steering shaft out cause I get a clunk in the steering and I feel it is time to grease the shaft and have a good look at it. I've read on here others have removed the clunk by removing and greasing the splines. I don't feel any slop in my u-joints.
Does it come out without removing the steering box?
