Steering Column Adjustment?
DFW, TX
Does anyone know if the steering column can be adjusted horizontally (left and right in relation to the dashboard)?
I was sitting in traffic this morning and I noticed my steering column is shifted slightly towards the passenger side, leaving a larger gap between the column and dashboard on the left side.
There are 4 large nuts that hold the column in place, under the dash. You'll have to remove the lower dash under the steering column to access them. They are either 14mm or 15mm in size. You might just need to loosen and adjust it a bit.
This did the trick!
There was about 1/8" of play in the wheel after I loosened the four nuts (you can see three of them in the pic). Just enough to get me back on center.
Thanks again!
