I apologize for the long read and the disarray of information below:
Coming back from a weekend off roading trip I stopped for gas. When I tried to start her back up it wouldn’t start. The starter does not turn, all I hear is a click. When I keep trying to turn the ignition over it will eventually start after many tries (about 5 minutes.) This starting issue happened again a week later (today.) Both times have been in warm weather above 100°F if that makes a difference.
I did notice that my truck was rough idling when offroading at high altitudes during the off road trip (roughly 10,000 feet.) Not sure if that is related to this as well.
Also: Prior to the trip I hooked up the battery backwards. I have since then replaced the fusible link. I currently do not have reverse lights and no passenger rear marker light. I am chasing that electrical issue down on the side, but once again it may be related.
Also… I have a new radiator that I installed as well as a trany cooler and replaced the trany fluid before the off road trip.
Also….I put new spark plugs in before the trip but did not set the gaps. The plug wires and distributor are also replaced within the last year.
I know not all this is related but maybe some of you with experience may see a connection. I have read threads about the FPR and other associated parts but cannot pin point my problem. The fuel filter was replaced within the last year so I’m assuming that is ok.
Any help with this bad starting issue would be much appreciated. I wanted input before running to Toyota to pick up an FPR for no reason.
-Randy
-Randy
