Hey folks.
I've searched this site up and down and have gotten really good information but am left with a dilemna. Here's the run-down.
A couple months ago my starter began to behave a little eratically. Every once in a while I would turn the key and here the solenoid click but no starter engagement. If I held the key long enough, or tried again, it would fire up. Only happened once in a blue moon. Lately it has been happening more often and has almost stranded me a couple times (I'm more patient than most). The other day I was headed out and it wouldn't start, I could hear the solenoid click, and my voltmeter is reading 12 volts. After 10 minutes of frustration I finally hooked it up to my wife's rig and jumped it. Low and behold it fired right up.
I read all the starter threads I could on this site and decided to check my contacts and plunger. Looked fairly good, so I had the starter tested and it seems that the starter is fine. Back to the search function and read up on ignition issues. It makes sense to me that I'm not getting enough current to the solenoid, so the 30 amp relay idea sounds reasonable. Here's where the questions begin:
1) If I want to run dual batteries (painless setup), does it make sense to add a 30 amp relay to my starting solenoid circuit?
2) I'm thinking that the smaller gauge wire to the solenoid, plus the relatively old ignition, is what's limiting my current. Will dual batteries help or will they be limited by the same issues?
Thanks.
Thanks.
