Tore the starter out on my 3FE this weekend as it would not start earlier this week (first time). A wack to the side of the starter got it home.
Question: How long are your contacts when they fail? FSM says standard is .513 and the limit is .332". None of mine were less than .42" in length and most a bit longer.
My failure appears to be with the 'plunger' solenoid. The pad on the one side had built up to a knob where I'm assuming it welded itself. Filed it down. Plunger contact appeared fairly decent but I don't get the best continuity across the two contacts. I have to press down just a bit to get good contact across.
So should I order a new plunger and contacts? Test benching it and it appears fine now. C'dans stuff takes about 4 days and I'd like to put it in soon.
