anyone done a extension on the breather for the split case? if so how did you go about it?
Thanks, I only ordered one of thoseIt is a pressed fitting, mine was pretty difficult to get out but some perseverance and vise grips did the trick. This is the part you’ll want, I have a length of hose on it right now but plan to plumb it up into the engine bay eventually.
There’s probably a similar breather on your transmission too, so that will need to be extended as well.
Yeah, I did mine when I took the transmission out to do clutch work. It might be quite difficult to get at with the transfer case in the vehicle. That said, I’ve heard that some of them come out easier than others; mine was really stuck but yours might come out easy.Thanks, I only ordered one of thosewill see if I can get another one pronto. Of course don’t know if I will get the old one out since the trans/transfer are still on the vehicle
I was under the impression that the fuel tank vented in the filler neck section which would be fairly high on the body.Looked up the part number and it looks like it is a pressed fitting. Didn’t think about the fuel tanks. Will have to think about that one
Probably not the last time today I’ll be wrong about something.Nope, at least not on my BJ73.
The check valve on the filler neck only vents the neck. On filling, air needs to go up the neck, as the normal tank ventilation can't cope with the hugh flow during filling. Additional venting with a bypass is required in case there is a choking in the neck which else would lead to bubbling and spilling then.
On my filler neck there is no opening to the air that wouldn't be closed by the filler cap.
I know some older vehicles also ventilate through the filler cap, but mine doesn't.
[sorry for my clumsy English]
On my 1985 BJ73 there is a hose that straight goes from the tank to a plastic fitting (90405-06008) that holds it inside the floor cross member.
Assumption apparently is that it is not affected by dust & dirt there. But when submerged to the floor, water can get into the tank, still.
Downside is: When not driving, evaporated fumes are emitted there, too.
Later vehicles thus usually have a charcoal container on the tank ventilation to catch emissions from the tank and emit it back into the tank when breathing in. But those still have an opening to the atmosphere where water could get in when deep fording.
Only later vehicles have controlled tank ventilation associated with the engine.
All I'm saying is: Also consider your tank ventilation when preparing a vehicle for deep fording.
Needed action depends on vehicle.
Happy bathingRalf
Hey, I also have been wrong on something in this thread already (pressed breather).Probably not the last time today I’ll be wrong about something.![]()
