Speedometer replacement question
How long is this going to take? I couldn't find any writeups i must be missing something, if there is could someone point me in the right direction of a link?
It seems fairly straight forward but if theres any secret I should know please let me hear it.
Is this something I can get done in an hour?
Thanks
it takes about five minutes. Disconnect the cable from the rear of your speedo, tape sting to it. Pull it through under the vehicle. Disconnect from transfercase. Tape string to new cable, pull through from inside cabe, reconnect. Besure to lightly lube new cable. To much grease and you speedo will be jumpy, not enough and it will break....good luck
This might be a dumb question but can I get to it from the back side? I mean without the dash apart?
