Speedo cluster
bridgewater NJ
How you get the speedo cluster out?It only comes out a little bit and then you have to disconect all electrical plugs in the back.There is so little room I couldn't fit my hand behind to diconect them.What is the trick?I searched Slee's web site for dashboard removal but couldn't find anything.Slapping the dashboard didn't work for me.I have both "D" and "P" out.
I remember there to be two screws/bolts on the bottom of the cluster, one on each side that holds in each wiring harnesse. Unscrew, disconnect harness then remove cluster.
In anticipation of your next question, here's some tips from 100TD:
"Pulling your dash and putting it back should be simple, if it is the same as mine that it, and from Dorons photos it appears to be.
The key thing to do is to get a screwdriver and fully undo the 2 big screws holding the electrical connectors to the back of the dash before moving the dash. Then get your screwdriver and push the screws in firmly so the connector releases and remove the dash. When putting it back in, first make sure the harness connectors behind the dash are clipped into the back panel and are snug and in possition. then put the dash in and it will line up with the connectors. when it is in place, do up the 2 big connector screws that pull the connectors together. Mine actually ratchet once they are tight. Job done! You don't have to get your hand behind to put the connectors on at all if you do this. This is how mine works, and the back connectors on the dash appear to be the same including the little red plastic bit which helps eject the connectors I think."
:cheers:
