For Sale Southern MD 03 tacoma SOLD
Decided to sell my ‘03 Tacoma LIMITED TRD off-road, this thing has been my pride and joy for a while now but unfortunately it is not fitting the needs of the family anymore so time for someone else to enjoy it. One of the most reliable vehicles I’ve ever owned and it will take you where ever you want to go. This truck also has a great frame, minor surface rust in spots but completely solid which if you know what your looking at you already know that was a problem with these. I’m very particular about maintenance and this thing always has its oil changed every 5k and diffs are done after every wheeling trip. This is a great base for your next adventure build and really has everything you need, just ready for your own touches. Don’t let the miles scare you, do your research these 3.4’s are bulit proof Toyota engines. With all the greats about this truck there are some bad’s and they are listed at the bottom, so read the whole ad. I also have a removable sleeping platform the mat I built for the bed that will be included in the sale. Asking 8700 obo Truck is located in southern MD 20676
Black sand pearl.
212,XXX miles
5 speed
4.10 gear ratio
Factory rear elocker
4wd
Limited with the colored key package
Exterior:
Marlin Crawler front bumper with stinger and winch mount
Nilight LED light bar
Depo clear corner lights converted to turn signals
Safari snorkel
4xinnovations bolt on rock sliders
Trail gear rear bumper with 4xinnovations swing out mounts (swing out not included)
Paint to match Raven cap with L-track mounting
TRD rock warrior bed side decals
Half smoke tail lights
2nd gen tailgate emblems
Trail gear rear tag mount
AVS rainguards
black SCS F5’s with 285/75 falken wildpeak a/t’s 4 wheels 5 tires
Interior:
Modified 3rd gen 4Runner seats
2nd gen Tacoma monster mats
Custom black leather shift boot
Pioneer DEH-3400UD head unit with USB
Focal door tweeters
Suspension:
Bilstein 5100 front shocks
OME 882 front springs
Camburg UCA’s
10mm top plate spacer
Extended brake lines front and rear
BDS rear shocks
OME dakar leaf packs with add a leaf
Toy Tech adjustable and greaseable rear shackles
Polyurethane steering rack bushings
Drivetrain:
3.4L 6 cylinder 5VZ-FE
Optima red top battery
Airbox deck plate mod
New radiator
New drive belts
New plugs
Timing belt last completed Jan 2013 at 146k miles
Custom 3 inch catback exhaust with Magnaflow muffler
Twin Hella super tone horns
A/C blows cold
Heat blows hot
Rebuilt HD Marlin Crawler transmission with Marlin Crawler HD clutch
New clutch master cylinder (not installed)
Oil change mobile 1 synthetic every 5k
Transmission, transfer case, front and rear diffs fluids changed at 210k miles
Rear differential breather extended to the gas filler
The Bad:
  1. Steering wheel could use a cover
  2. The power steering rack leaks ( the top seal where the Column attaches ) the rack needs to be removed and the seal replaced
  3. Clutch operates fine, but some times the pedal does not come all the way back up on its own, hence the reason for the new uninstalled clutch master cylinder. Never bothered me that much so I haven’t got around to installing the new one
MORE PICS APON REQUEST, call or text 443-602-6300 serious inquiries only
Oh man, I just got home from OC MD, glad I didn't see the $ before, I probably would of drug it home.
Great deal!
Good luck with the sale!
I wondered if I would ever see this thing listed. Damn I want it. You want a GX470?? You already have my 100...
To many rigs as it is lol. Sale is already pending, guy is supposed to be here Saturday to drive it home
