- Year
- 2017
- Vehicle Model
- Tundra
- Location
- California United States
- Mileage
- 46991
- Color
- white
Testing the waters on my 2017 Tundra overland build. This truck has been dead reliable, with occasional use in the deserts of Southern California and Baja. The truck has over $15,000 of newer parts and work performed on it in the last 2 years/3K miles. Most work was done at 4 West 4 Wheel Drive. I had the fuel pump replaced by a Toyota dealership ~1000 miles ago, but learned the actual problem was a loose aftermarket fuse. So it has a brand new fuel pump for what it is worth.
This truck is generally among the most capable on group trips.
Truck Details:
Build Details:
I’m happy to answer any questions about the build.
Asking 42K
Truck Details:
- Milage: Approximately 47K
- Year: 2017 SR5 with TRD Offroad Package
- Engine: i-FORCE 5.7L V8
- Double Cab 6.5-ft bed
Build Details:
- Foam Cell Pro 3.5” Lift Kit (Heavy Load)
- Front Coilovers
- Rear Leaf Springs
- Foam Cell Pro Rear Struts
- Poly Spring Bush Kit
- Rear greasable shackles
- Rear U Bolt
- Brake Hose Relocation
- Rear Driveshaft Center Bearing Spacer
- Upper Control Arms
- 4MM Steel Iron Man Skid Plates
- White Knuckle Offroad Rock Sliders
- Iron Man Raid Front Bumper with Hidden Winch
- Iron Man Raid Rear Bumper
- 12000 LBS Hidden Winch with Synth Rope
- Ready Lift Differential Drop Kit
- 5 Method 17x8.5 MR703
- 35” KO2s - 80% tread left
- Total Chaos welded Control Arm Cam Tab Gussets
- Body Mount Chop to clear larger tires up to 37”
- RCR Force 12 Switch Panel mounted above windshield
- upTOP Overland AFS Roof Rack
- Driver side handle
- A lot of little things not mentioned (Battery mounts, etc.)
Asking 42K
