Located in middle tn.
Open to reasonable offers.
1997 Lexus LX 450 Triple Locked
233,xxx Miles
-Nearly every seal, hose or maintenance part in the engine bay has been done within the last year. Distributor, spark plugs, spark plug wires, harmonic balancer, belts, hoses, thermostat, fan and fan clutch, radiator, heater valve, valve cover gasket and more are all new. Nothing was wrong with it when I bought it but I wanted to do everything I could to make sure it was as reliable as possible so I did a complete maintenance overhaul. Most of what I replaced was kept as spares which will go with the car. All fluids have less than 1500 miles on them.(Engine Oil, Coolant, gear oil in axles, etc.)
-37x12.50r17 General Grabber x3 MTs
-17inch DirtyLife Beadlock wheels
-Trussed and armored front axle that was completely rebuilt with all new seals and bearings.
-Trail Trailer Transmission and Transfer skids
-Icon Dynamics 2.0 Shocks
-C97-145VT Dobinsons rear springs
-Icon Slinky Springs in front
-SLEE Stainless extended brake lines all around
-Pin 7 Mod for Center Diff Lock control
-Apple Car Play Head Unit
-Auxbeam 8 circuit switch mounted in custom headliner mount
-Wolfbox Mirror w/ front and rear cam and video capture
-ARB Safari Snorkel
-Scar 10s Winch
-Coastal Offroad front high clearance bumper
-Coastal Offroad Welded on Sliders
- Custom made High Clearance rear bumper ready to accept a swing out. (I mean really high clearance!)
- Homemade organization system in the back that accepts two rows of Milwaukee Packout boxes and a sleeping platform
- One Milwaukee Packout full of spare parts and fluids included
- Upgraded adjustable Panhard, drag link and tie rod.
-Iron man Adjustable Lower rear links
-New OME steering stabilizer
-Prinsu Roof Rack
-Renology battery monitor
-3d printed cup holders
-Dash mounted RAM mounts
-Eimkieth Radius arm and rear panhard relocation
-Custom exhaust reroute to eliminate low hanging exhaust. FlowMaster 40 muffler
-ABS and LSPV delete.
-sway bars removed
-I have 4.88 gears for the front and rear that are not installed
- Spare front axles, front and rear drive shafts, windows, and more. I parted out another landcruiser and kept tons of spares just in case. Comes with a waterproof box to carry axles and shafts on the roof rack.
-Fresh Candy Apple Red Paint Job - painted due to removing the trim and professionally welded all the trim grommet holes.
-3 full size matching spare tires 37x12.5 General Grabber x3
