Recently the dash lit up like like a Christmas tree w/ the annoying whine. ABS, Atrac, 8 track, half track and other lights came on. The power in the power brakes became intermittent then died completely. The booster motor at the bottom of the master cylinder was not working. 15 years, 192,000 miles.
Here is my chance to give back to the forum something helpful:
I found the following shop in Santa Ana, CA that does a lot of these rebuilds. Tim (owner) prefers to have you bring in the whole master cylinder and he usually has a booster motor on the shelf to swap it out. I waited 15 minutes and he was done, installed. $250 out the door, one year warranty. I remember he said new commutator, brushes, and maybe windings. Tim advised there are two types of motors, a heavy duty one and a light duty one. The Landcruiser/LX470 use the heavy duty one.
This can be an expensive repair so this is a money saving option for some. The shop's a little dusty but he knows his stuff. They also repair ECU's there.
Auto Electric Rebuilders
1421 N. Harbor Blvd
Santa Ana, CA 92703
714.554.1515
I rebuilt the M/C with the new piston. Easy job. After bleeding the brakes, the lights and alarms were still on. A little worried that the accumulator was bad. I started it the next morning, the reservoir level went down about a half inch and the lights/alarm went out. No codes stored. Must have worked out the air in the system. ABS works.
I previously had always had a spongy pedal that went 3/4 down. Now the brakes are firm and in the top third of pedal travel.
Always good to have options.
Tom
1421 N. Harbor Blvd
Santa Ana, CA 92703
714.554.1515
Tom
