I’m sorting through a few problems and just need to ask for some help.
- Is there an FSM that has the 1FZ-FE with an H151 or H155? I’m curious on a few things.
- When removing the wiring harness to pull the motor, what disconnects on the 5 speed side of the harness?
- I’m told that there are changes to the wiring harness for the 5 Speed, where are they? I’m getting a new harness and need to change whatever is needed.
- In order to pull the motor separately from the transmission, what needs to be done? I’m guessing removing the harness from whatever it’s connected to on the trans. I can get to 7 or 8 of the bolts, but the top 3 or 4 require it to be dropped a little correct?
- If you take off the upper heater hose, and then disconnect the lower return hose, then insert a water hose into the upper hose where it enters the motor and turn on the water, shouldn’t it come out the bottom with some force? I get water, but not at the same amount or pressure of the hose going in. It was a little sludgy at first, but it runs clear currently.
- Motor runs well, but oil pressure is always at L side, I don’t think it ever moves. I’m guessing that it’s the oil send switch that’s the culprit.
- Fuel indicator wasn’t working, I replaced it with a known good one. Still shows empty all the time, but the orange light only comes on when I’m actually close to empty. Guessing that it’s the float or something going on with the unit in the tank. Likely?
