Socket size for crank pulley bolt?? Real Time
Somewhere in NJ
I believe it's a 22mm bolt.
30mm for stock crank bolt and 32mm for the a new crank bolt if there is a S/C on your 80
Thanks
I got the 30mm, worked like a charm. Checked and rechecked valve clearances, which leads me to a new thread...
Well, since a 30mm socket worked, I guess it's a 30 :o
I got the 22mm size from the TRD/Kazuma installation manual. It says on the parts page as well as the section regarding the crank bolt, that it's a M22-1.50 x 90mm bolt. Likely the original Toyota bolt is the 30mm jobber.
The M22 is the diameter, 1.50 is the thead pitch, and the 90mm is the length :D
Gee...thanks Todd. That just makes my embarassment even greater :o
