Aim, I've used Seafoam on several vehicles, and for most I've found that the PCV line is the easiest way to feed all cylinders. It's not ideal on the LC becasue it's behind the throttle plate like you mentioned, but it worked for me. I wasn't sure of the purpose of the other line or what it fed into, so I didn't want to risk anything. However, if you're confirming that it dumps right out BEHIND the throttle plate in the manifold, then I'd be willing to give it a try. The clearer the path, the better.
Also, I know that there are many naysayers out there, but the Yukon I just sold failed emissions for the first time ever (after I sold it and bought the cruiser, of course). I thought that I was in a bit of a pickle, because according to CO law, the seller is required to fix any emissions related problems, or buy the car back. Scary. I found out that the reason for the failure was that Colorado just started testing for NOx (oxides of nitrogen) for the first time in 2010. For whatever reason, they had never tested for this before, but the Yukon just
barely failed so I thought it would be a simple fix.
NOx is cause by high combustion temps, and through my research I found that the most likely cause is a bad EGR valve, a partially clogged injector, or carbon deposits built up in the combustion chamber that soak up fuel and cause the engine to run slightly lean.
I did the following to try and remedy the situation:
1. Cleaned the existing EGR valve with electronic-safe cleaner (due the the sensors built into it), and replaced the gasket. Whoops, it didn't like that. Dicked the thing up and made the NOx score increase.
2. Replaced the whole EGR valve and gasket. Back to where it was before I screwed the old one up. No appreciable improvement - it still failed.
3. Out of desperation, I ran some seafoam through the PCV valve, and put the rest of it in the gas tank. Told the new owner to drive it around for a couple of days to let it work a little, and guess what? IT PASSED.
I wouldn't have spent $130 on an EGR valve if I had even fathomed a $9 can of seafoam would have done the trick. I guess starting cheap is always the best way to go.
Sure, it could have been a coincidence. Say what you want, but I will continue to use the stuff every now and then.
