I really don't think I have a problem but want to run this by you guys. I have recently been concerned with a smog/air pump that was occassionally sticking and so my belt would screach and, voila it would unstick. So the day I had a belt burn up in an instant, due to the pump siezing I decided to look into a solution. The final solution after many different opinions is I gutted the pump, left the shaft and bearings in place (impellers/propeller were rusty) to use the pulley and same belt sizes. Per a local mechanic, I left the hoses attached (to and from the pump)as it will not cause any problems.
What do you guys think? Will this cause a problem to my Catalytic or overheating issues? Or what?
Thanks all
Crossposted to CCOT forum.
Thanks all
