I noticed this small coolant leak. Is there a clip missing on the hose here ? The hose feels very lose.
Thanks for the tip ! I was planning on adding two zip ties but might just do what you said.I don’t think there is a clip, it should be close to atmospheric pressure, just to the bottom of the coolant reservoir. I’d slide the hose off the nipple and clean the inside of it, and the nipple, then see if it keeps leaking. If so consider a zip tie that you can get snug.
A tip for zip ties on hoses.. if you wrap it around twice before inserting into itself this eliminates the little angle gap that is normally formed where the tie goes into the lock.
Probably your best bet. Part number should be 16477-50220Thanks for the tip ! I was planning on adding two zip ties but might just do what you said.
Is it correct that the proper fix would be getting a new hose and that this one is just... tired ?
