Africaster
Use weed wacker cord … cheap, easy and won’t scratch/damage … I’ve had to “open” the gap in the bottom seam a little for faster drainage - flat head screwdriver works, just a little twistHow did you unclog?
Glass can be removed by popping off the black interior trim and removing the 4 cadmium plated nuts. The entire glass will then lift straight up off the truck and you can clean your drains.I am unable to open or tilt my sunroof, so I cannot check the drains. I can hear a small motor noise when switching between 'tilt' and 'open' buttons, but nothing moves. I am assuming that is a major mechanical repair of the sunroof. I'd rather spend that $$ somewhere else and just seal it up.
If was was to attempt a repair, I am guessing the headliner has to be dropped to gain access to the mechanicals, yes?
