I searched and found a couple similar, but not exact:
2000 LX470
184,523
All stock
This last Tuesday, driving ~45mph on straight and level dry pavement, the SLIP INDICATOR (car symbol with wavy vertical lines under it) came on, beeped continuously and the FRONT RIGHT wheel locked up, pulling the truck to the right.
NOTE: The ABS, VSC and ATRAC lights do *NOT* come on when this happened.
I took my foot off the gas and steered to pull over... then it stopped.
Happened again approximately 1min later.
Since then the light and alarm (beeping) has occurred twice under similar conditions, but without locking the wheel.
A friend has access to a SnapOn VERUS computer, and we pulled the following from the ABS component:
DTC List:
5340H/21312 Undocumented Code
There were no other codes present.
I called the nearest Lexus dealer and spoke with their head mechanic - he called me back a while later to say he couldn't find anything on that code (hence 'undocumented') and said the one time he's heard of a locked wheel, it was the RIGHT REAR wheel speed sensor that had gone bad and the truck was trying to correct for a non-existent skid condition.
I have not been able to intentionally reproduce this issue (light/alarm or wheel lock), driving at speeds above 45mph on straight, level and dry pavement - and after reading the *similar* issues on here, I intentionally took a curve at speed (in both directions) - but the truck handled as I would expect.
Here's my big problem: I'm in VA visiting family since turkey day, and need to get home to MA. I don't wish to make the 500 mile drive in constant fear of a wheel locking up.
I also don't have the money to get this sorted out right now.
Since the Slip Indicator light is the only one that comes on, is it possible to disable ONLY that part of the system, or would the entire ABS system have to be disabled (until I can get it fixed).
Does anyone have any other ideas?
2000 LX470
184,523
All stock
DTC List:
