Long time reader, first time posting. I have a 97 LX with 159000 miles. I think I have one or two problems with my LX. The first problem is what I am going to call a slight shimmy while at idle. Cold or warm. More noticeable when warm and idle is around 650 rpms. It will idle normally for a few seconds, then have a slight shimmy, idle normally for a few more seconds, then a slight shimmy, and so on and so forth. No rhyme or reason. It happens when the vehicle is in gear or park\neutral. It is not felt or noticed while driving. This problem seems to be more pronounced after the vehicle has been started and shut off numerous times throughout the day.
The next problem could be related to the first(but I doubt it), since it started around the same time. It is a engine related vibration or hum, which I will compare to a deep bass vibration from a stereo, which resonates through the engine compartment, into the foot feed and floorboards and into the cabin. Both the tranny and transfer case shifters vibrate, more so with the transfer case shifter. It only vibrates/hums when the vehicle is in gear, and is rpm sensitive. It is also loud. Meaning it sounds like I have an aftermarket exhaust(like a turbo muffler) under it. Again, it sounds normal when in neutral/park. Peak vibration/hum is around 1600-1900 rpm. It seems like it is more noticeable just after starting and putting into gear, then warm. Again, it is exhasberated when the vehicle has been turned on and shut off multiple times durning the day.
With that being said, what I have done...New plugs wires, cap, rotor. I have sprayed a fine water mist above the coil--no results. Sprayed brake clean above the intake--no results. Half assed cleaned the intake inlet( did not look all that bad) --no results. Checked the intake snorkel for cracks, and checked vacuum hoses--nothing. Ran Sea Foam thru it. Put a new stock muffler on it(that was bad, leak towards the rear) It seem to be even more loud with the new muffler on it. When I had it in the shop, the tech checked the motor/tranny mounts, which if I can trust his judgement, are OK. Added two more exhaust hangers, but the rest of the exhaust is original. It feels and sounds like exhaust when the vehicle is in gear, but that theory gets tossed after revving it while in neutral or park. No check engine light.
Any insight would be appreciated!
