Slee 4", When?
offroadkid
GOLD Star
Shingle Springs, California
I haven't seen any threads talking about when the new 4" Slee lift is going to be ready for sale. Anyone know? Christo?
I heard sometime around mid to late Feb...but that's just what I heard -- not from the source though so I take it for what it's worth...
You thinking about 4"?
You saw the 4" eye candy thread ?
Slee made a very brief comment on his up and coming 4" lift . He mentions that it will have heavier spring rates than the 850J/863's , but will still achieve a fairly level attitude . The coils are designed to work with a heavy truck . IE : Bumpered , slidered etc etc .
Dats all I know :)
TY
Yeah, something taller than my set-up. I like Tyler's set-up, (I would need some J's for the front, and the caster plates), but I'm curious to see what the 4" is going to be like.
I installed the cup holder recently ... and on a drive tonite , I think I spilled more apple cider than I actually drank ! :rolleyes: Seems I need to load the rear with more weight . I'm hoping the full size spare on 16x10 steel , and the replacement of the jumpseats will cure my bucking bronco *L*
TY
TY
T Y, i bet you just need to wait a tad and let the springs settle a little. I know when i got my lift it was a bucking bronco for about 2 months. Then it smoothed out. Adding weight helps a ton. Oh, and check the air pressure you are running in the tires.
All this talk is great and all, but...Christo...Christo???
Maybe Christo will bring a REALLY BIG TRAILER to Cruise Moab. And we should bring our check books and cash!!! :D
:D :D :D
:D :D :D
Like this one? :D
OK, here is the skinny. Ordering production springs this week. Coming sea freight from Oz, so we are looking 6-8 weeks soonest. Rest of the parts will be shared with 6" kit, but use caster plates instead of arms.
sleeoffroad said:
Like this one? :D
Thanks Christo!! :D
Christo, is there a maximum tire size you recommend for the soon to be 4 inch lift? Or more to the point would you recommend 35's for this lift?
Also do you know the difference in castor correction between the arms and the plates?
Thanks,
:bounce: :bounce: :bounce:
:cheers:
Sounds great!!! Thanks Christo!
Thanks,
With correct bump stops you can run 315's if the tire/wheel combination is correct.
As for correction in caster with arms & plates, have not done a direct comparison measurement on the same truck. They are probably pretty close with the plates a little less. However plates will always be a compromise solution since it does not address the rearwards axle movement with large lifts. Also grinding of control arms are necessary to ensure that tie-rod and arms do not interfere with each other.
