Skid plates - replacement bolts?M
Iowa
Hello, does anyone know what type of bolts do I need to order to replace the current bolts on the OEM skid plates? Mine look like have been used too many times and they are getting harder to install.
Thanks
Yes, I think that’s it, thank you Cole. I’ve checked camelback Toyota for splash guard plate and I didn’t see it
Thanks
Hi. Thanks for all the help found here
I am looking for part numbers for the following on a 200 series left side skid plate:
  1. screws/bolts that fit into the welded nuts. Circled red in the picture
  2. the foam protective element. Red arrow in the pictures
Thanks in advance
The numbers Tony posted are for the m8 bolts that hold the metal splash shields on.. they have a 12mm head. I suspect the OP might actually need the M6 bolts with a 10mm head that hold the side plastic pieces on in front of the wheels.. they go into the captive nuts in the metal shields.
If so, I replaced the M6 bolts on mine last week. Six of them needed to get both sides. 90109-06375
The foam block is 88578-60391
Note that the two sides of foam are different. Driver side is shorter and as a result easier to remove that skid plate, on account of it being necessary for an oil filter change.
Thank you. Yes! It is the 10 mm head. Much appreciated
You mention that the foam block for the left and the right are different p/n. Would you have the p/n for the right side?
Thnaks again
Thnaks again
They are different lengths on my truck, but the diagrams list the same number for both sides. Also they are categorized as “std part” so I’m betting it is cut to fit.
