Signals not working but hazard do work
Hi - was hoping someone can help with this. I changed my bulbs in the front and side markers for my HDJ81 - everything was working just fine. Later that day, the turn signals stopped working (coindidence?) However, the Hazards still work and wipers, headlights also work. When I try and put on the turn signal, nothing happens. Any suggestions? Thanks.
DId you replace the bulbs with "bulbs" or LED's?
Old bulbs do not work - actually only changed front turn signal bulbs. Didn't change side marker bulbs - just lenses. Signals worked all day long and then...nothing. Is there a fuse that may be affected. I also read somewhere about grounding?
Are saying that when you activate the turn signal lever it will not stay locked in that position?
If that is your case you may have a faulty turn indicator lever or something is a miss in that area.
No, the lever seems physically fine and locks into place but neither turn signals lights nor dash indicator lights work at all...
Since the flashers are on there own fuse, does the signal run off there own flasher relay? If so you may need to replace it. Next do you have any trailer light wires in the back? They may have caught on something and need repair.
Just some thoughts
A little late but for the next guy: if you just changed the lights and this happened with hazards still running check your fuse. The same thing just happened to me. It on your kick panel just to left of steering wheel. 7.5 fuse $3.00 for pack of 5 at auto zone. It’s in “Turn” slot on diagram. I attached picture.
