Thank you for the response. What do you mean by pull the door card? Does the whole door trim panel have to come off?To remove (for 01 LC, prob the same for you), remove 3 bolts behind tweeter/cover. DON'T remove the small screw - that is what prevents the mirror from falling and breaking. Then pull the door card so you can unhook the connector. Lift out mirror and replace in reverse. Should be <15 mins total.
Thanks for the help. All done.It does. The wiring is behind it.
sorry, i forgot that if I posted in something, it wouldn't notify me of replies. But now see that it's all done, glad it worked out.Thank you for the response. What do you mean by pull the door card? Does the whole door trim panel have to come off?
