Shoulda, Woulda?
Montana
What are some things that you should have, or would have done on your builds that you didn't?
I am prepping my body now to get everything ready to bolt down within the next few months. I would like to hear from people that have pulled their tubs on things they wished that would have done prior to putting the body back on. Tub, frame, axles, whatever.
Let's hear it.
1980 FJ40. Now I wish I had done the rear disk brake conversion. I thought keeping it original was a better choice at the time. On well.
I made mine too nice to want to use like it's meant to be. I take our Tacoma or 4Runner out, while the 40 sits in the garage. I would have spent less on paint/body/looks, then I'd be less upset when it got hurt.
Therapy can help, Riley... ;)
Especially, therapy that includes :steer: it and :D
:cheers:
Tons of work, but I wish that I put it all together after metal work, and filled any holes that were not going to be used made any modifications to the tub for fitment of panels, etc.
Think ahead... I wish I had done my metal work with a might welder instead of flux core. Now some of my patches are showing my inexperience 16 years later.
I wish I had properly braced my tub and taken more measurements prior to cutting the tub and corners out.
I wish I had put on 1 or 2 more primer coats. 2 was good, but more would be more better.:hillbilly:
I wish I had cut my rockers up when I had the tub off. Not a biggie, but would have been easier, for sure.
I haven't done a frame-off, accidental or otherwise...
But, I have followed your 'Accidental Frame-off"...
... And am impressed with your ability to channel your inner rage into such a creative result...
You have learned a lot, gwasshoopew... And it definitely shows...
Your attention to detail is beyond reproach...
... And your FJ40 will be a work of art!!
I don't drink, but, having witnessed your metamorphosis, I think the best I can offer is 'more beer' and, perhaps, the gravelly lowing of Leonard Cohen... He has soothed me and helped me through many frustrating endeavors.
Keep up the great work, Ryan!!
:cheers:
I should have put bedliner on underside of front fenders and rear wheel wells. Front fenders are all chipped up with several dents and spider cracks in the paint from the dent. Oh well
I am planning on using Monstaliner on the underside of the tub, basically for that reason and to try to keep the Mid-Atlantic rust monster away.
I have 2 gallons of primer to shoot, I am pretty sure I can get a few coats on, then the Monstaliner on the underside.
I feel I did alright bracing the tub when I cut it, and I tried to work small areas. Until I got to the floor pan and rockers.
Sometimes when I am working on one area trying to make it look perfect I remind myself that I am not making a show rig, it is going to be something I can enjoy.
I would have not bought my 67 as i was a complete cruiser newb and missed all the warning signs and trouble spots to look for.
I wish I would have seen the spacer laying on the bench that went between the tranny and the TC gears prior to completely assembling the entire vehicle only to find the tranny didn't shift properly!!
I had several bolts and a couple of broken body mounts underneath that I forgot to take care of prior to painting. Drilling them out after paint was frustrating.
Being as I wheel my junk, I would work on frame stuff while fully accessable with no danger to body. I would cut the center of the rear crossmember open and put a 2" receiver directly into the frame. No ground clearance issues.
I have also taken to welding steel plates inside the front channels of the frame behind the bumper where there are holes in the frame. That way I can drill and tap those plates for accessory mounts later, especially if the holes become inaccessible due to something like power Steering mounts.
I would grind the rivets out of the steering box pedestal and replace them with bolts, so if you do a Saginaw conversion later, you won't spend years looking at a pedestal you could have prepared for removing.
And there are shock mounting considerations.
Bed liners will eventually fail also, although hopefully slower than paint. The question is not which is better or more protective, but which is easier to remove/repair when the failure does occur.
