Shoulda, Woulda?
Bed liners will eventually fail also, although hopefully slower than paint. The question is not which is better or more protective, but which is easier to remove/repair when the failure does occur.
In the bedliner vs paint failure debate, I prefer paint because you can SEE the failure sooner, so you can treat the rust sooner. Some bedliners can hide the rust until the metal is GONE!:eek:
Being as I wheel my junk, I would work on frame stuff while fully accessable with no danger to body. I would cut the center of the rear crossmember open and put a 2" receiver directly into the frame. No ground clearance issues.
I have also taken to welding steel plates inside the front channels of the frame behind the bumper where there are holes in the frame. That way I can drill and tap those plates for accessory mounts later, especially if the holes become inaccessible due to something like power Steering mounts.
I would grind the rivets out of the steering box pedestal and replace them with bolts, so if you do a Saginaw conversion later, you won't spend years looking at a pedestal you could have prepared for removing.
And there are shock mounting considerations.
And suspension mods. If you knew what your shackle angle was, and wanted to improve it, there would be no better time to cut the hangers loose and move them. Did it on both 40s; love it.
Drivers side still stock, for comparison. Relocated hanger and DD shackle allow over 2” more droop.
Which is the reason I am still working on my tub, the bedliner was placed on top of crap work, patches of bondo the size of your hand. If I lived in an area that I didn't have to worry about the salt, mag chloride, and rust developing non stop I would not have decided to go with the Monstaliner on my tub. All I can hope for is that I can seal it the best I can, I know the metal work is being done, all the rust I can cut out and remove is gone. 2 gallons of epoxy primer are going on the body when I get done with the metal work, then the Monstaliner, hopefully that will seal it up for 10 plus years.
I wish I had taken off the crappy plastic rear fender flares (that a P.O. installed) right away, and repaired the hack-job quarter-panel cuts, instead of waiting to break them on the trail and then discovering said hack job quarters that I've lived with ever since.
Well, I just started a frame off rebuild of my Vermont rust bucket and I'm planning on regretting not doing a nicer looking job with the paint. But I've waited over 20 years to replace the rotted frame and I'm pretty sure I won't be able to resist rushing the finish work and slapping it back together so I can finally drive the damn thing. Anyway, the Vermont woods are no place for a pretty truck, as my banged up FJ62 demonstrates.
I would of liked to have known about this forum before doing any work at all. Everything I did or had done was with no knowledge of how to do any of it. After five years in the body shop, the owner asked me to come and put it back together, because he forgot where the parts went. Not his fault, as it came to him in a few pieces. As I begin to finish this project, this forum will be of great help.
In the spring I should start a thread for the resurrection of Ruthie.
Shane
As mentioned, and I've heard it before. If you fix it up too much, you will be afraid to drive and enjoy it.
i would have done my front dics brake conversion and power steering install. had to take the front fenders off to do the power steering and even the tub got in the way a bit. also would have painted my engine...
This is my greatest fear. My truck requires some (minimal, compared to most) body work, and I'll likely paint it someday, but I'm truly afraid that once I take the body off, do the work, paint it, and put it back together, I'll be afraid to drive it.
Other than that, my only regret (so far) is not buying a better truck to start with - if I'd known then what I know now, I would have either talked the price down more on this one, or bought a different truck altogether. That said, it's nothing that time and money won't fix.
I have been looking at the idea of welding in some bracing for the fold and tumble I am installing. Something more substantial than sheet metal.
I like the thought of welding all the unused holes, anything with threads I am running the proper sized fastener into.
Sliders have been crossing my mind in the last few weeks, after replacing the inner and outer rocker on the drivers side. I don't want to make that repair again.
As stated by others, I wished I had bought a better 40 to begin with. I was blinded by the pretty paint. Only to find that it was owned by a bondo bandit.
I'm in the same boat...if I could do it all over again, I would spend a year on this forum before buying a 40. Of course, buying a 40 shaped pile of bondo helps justify other purchases like welders with the wife. So there's that. Good thread, thanks for posting.
Meh, mine was a restoration originally. Repaired all rust, sandblastedl, primed and paintend every little part. It looked awesome. Then I started wheeling it. I never thought it was too pretty to wheel. I've put a few scratches in it in the ensuing 16 years
.. also wheeled Rubicon and I put my 1st significant dent in it last summer at CMCC at Rausch Creek. I dented one of the only 2 original non rusty parts, the PS front fender.
When I got home I banged it out a bit and painted it.
You can wheel it, use it and still keep it rust free and looking good.
Show cars they ain't.
Updated with pic, post #22
I am in the process of redoing mine. i am going to paint the frame and underside of the tub and fenders with a few coats of zinc paint than epoxy than paint.
