Should oil filter for the US 1985 Diesel Pickup 2L-T work on my Bundera?
I've contacted a few Toyota places in the US and the Toyota number for the US imported 4x4 pickup 2L-T in 1985 is currently 90915-yzzD3. The is apparently the same filter that is used by Toyota in many gas truck engine applications as well. Any thoughts on why this wouldn't work in my 1986 Bundera/LC II/LJ70 that also has a 2L-T?
The supposedly correct non-OEM filter out here in Liberia is big money as is the air filter, which is a MANN C16136. Bringing some US filters in my excess luggage would save me alot of money.
Thanks,
Rich
Yes, that is the correct Toyota part number to use. The 15600-41010 is now discontinued in the US. 90915-YZZD3 is the correct replacement part. Don't forget your drain plug gaskets as well: 90430-18023
Toyota lists out the oil filter at about $5.41.
Try this...some discussion on large hole or small hole and there being an adapter.
If you have the large hole the adapter may be removeable and or obtainable?
The filter PO100 is a Phoenix from Ebay Aus.
Good luck.
http://www.ebay.com.au/itm/PHOENIX-...ccessories&hash=item2c709c9194#ht_5219wt_1064
If you have a turbo go with the largest filter possible, is your filter vertical or horizontal
Make Type Model Engine Year Pho. No. X Ref.
FORD FAIRLANE ( 6CYL ) NC EFI 7/91-3/95 PO100 Z9
FORD FAIRLANE ( 6CYL ) AU w/o IRS EFI 1999-02 PO100 Z9
FORD FAIRLANE ( 6CYL ) AU w/ IRS EFI 1999-02 PO100 Z9
FORD FAIRLANE ( 8CYL ) AU EFI 1999-02 PO100 Z9
FORD FALCON (6CYL) XK 1960-62 PO100 Z9
FORD FALCON (6CYL) EA w/ Throttle Body Inj' 1988-91 PO100 Z9
FORD FALCON (6CYL) EA w/ Multipoint Inj' 1988-91 PO100 Z9
FORD FALCON (6CYL) AU w/o IRS 1998-02 PO100 Z9
FORD FALCON (6CYL) AU w/ IRS 1998-02 PO100 Z9
FORD FALCON (6CYL) BA ( LPG Only ) 6CYL 9/02-9/05 PO100 Z9
FORD FALCON (6CYL) BA ( Petrol Only ) 6CYL 9/02-9/05 PO100 Z9
FORD FALCON ( 8CYL. ) AU Windsor w/ IRS EFI 1998-02 PO100 Z9
FORD Mustang 3.8L V6 1994-00 PO100 Z9
FORD Explorer Auto 4.0L V6 6/99-01 PO100 Z9
FORD Explorer Manual W/O DOM 4.0L V6 6/99-01 PO100 Z9
FORD BRONCO 4.1L 1928-85 PO100 Z9
FORD F100 SERIES 4.1L 6 CYL 1974-78 PO100 Z9
FORD F100 SERIES 4.1L 6 CYL 1978-81 PO100 Z9
FORD F100 SERIES 4.1L 6 CYL 1982-85 PO100 Z9
FORD F100 SERIES BRONCO 5.0L V8 1985-87 PO100 Z9
FORD F100 SERIES ALL MODELS V8 1963-74 PO100 Z9
FORD F100 SERIES 5.0L V8 C 1974-78 PO100 Z9
FORD F100 SERIES 5.0L V8 W 1985-87 PO100 Z9
FORD F250 SERIES ALL MODELS V6 1963-74 PO100 Z9
FORD F250 SERIES 4.1L V6 1974-78 PO100 Z9
FORD F250 SERIES 4.1L V6 1978-81 PO100 Z9
FORD F250 SERIES 4.1L V6 1982-85 PO100 Z9
FORD F250 SERIES ALL MODELS V8 1963-74 PO100 Z9
FORD F250 SERIES 5.0L USA IMPORT V8 W 1993-96 PO100 Z9
FORD F250 SERIES 7.5L USA IMPORT V8 1987-96 PO100 Z9
FORD F350 SERIES ALL MODELS V6 1963-74 PO100 Z9
FORD F350 SERIES 4.1L V6 1974-78 PO100 Z9
FORD F350 SERIES 4.1L V6 1978-81 PO100 Z9
FORD F350 SERIES 4.1L V6 1982-85 PO100 Z9
FORD F350 SERIES ALL MODELS V8 1963-74 PO100 Z9
FORD F350 SERIES 7.5L USA IMPORT V8 1987-96 PO100 Z9
FORD FORD UTE Falcon Outback Ute XH 4/96-6/99 PO100 Z9
FORD FORD UTE Falcon XR6 Ute 4/96-6/99 PO100 Z9
FORD FORD UTE Falcon Ute AU 4.0 & 5.0L 7/99-02 PO100 Z9
FORD FORD UTE Falcon Ute BA 4.0L 6cyl 2002-on PO100 Z9
LANDROVER COMMERCIALS 110 Series V8 Petrol 1984-91 PO100 Z9
Range Rover 3.5L V8 1986-93 PO100 Z9/Z89
Range Rover F series 3.5L V8 1979-on PO100 z9/89
Range Rover 3.9L V8 1988-93 PO100 Z9
B2500 Turbo PANEL FILTER 2.5L 6/00-on PO100 Z9
B2500 Turbo 2.5L 6/00-on PO100 Z9
MITSUBISHI VALIANT (6 & 8 CYL.) VG w/ 1 Barrel Carby' Hemi 6 1970-71 PO100 Z9
MITSUBISHI VALIANT (6 & 8 CYL.) VG w/ 2 Barrel Carby' Hemi 6 1970-71 PO100 Z9
MITSUBISHI VALIANT (6 & 8 CYL.) VK 245ci Hemi 1973-75 PO100 Z9
911 2.2L 1966-71 PO100 Z9
RAMBLER All Models V8 1958-89 PO100 Z9
TOYOTA Corona MX10,13,22,23
Cressida Air Pump 6cyl 1972-77 PO100 Z9
TOYOTA Crown 2.0 & 2.3L 1966-71 PO100 Z9
TOYOTA Blizzard 2.2L Diesel 1982-84 PO100 Z9
TOYOTA Bundera BJ73 3B 1985-86 PO100 Z9
TOYOTA Bundera BJ74 13BT 1986-87 PO100 Z9
TOYOTA Bundera LJ70 2L-T 1986-89 PO100 Z9
TOYOTA Coaster Bus 3B 4cyl 1978-6/92 PO100 Z9
TOYOTA Coaster Bus 3.4L 4cyl 1993-on PO100 Z9
TOYOTA COASTER BUS PETROL 5R 1971-77 PO100 Z9
TOYOTA Commuter Bus 3L Diesel 1990-93 PO100 Z9
TOYOTA DYNA 4 CYL. DIESEL LY60,61,150 2.4L 1985-91 PO100 Z9
TOYOTA DYNA 4 CYL. DIESEL LY61R,150 2.8L 1988-8/92 PO100 Z9
TOYOTA DYNA 4 CYL. DIESEL LY61R,211R 2.8L 8/92-04 PO100 Z9
TOYOTA DYNA 4 CYL. DIESEL BU10,20 3.0L 1972-85 PO100 Z9
TOYOTA DYNA 4 CYL. DIESEL BU60,63,200 3.0L 11/85-98 PO100 Z9
TOYOTA DYNA 4 CYL. DIESEL LY220R,230R 3.0L 2001-on PO100 Z9
TOYOTA DYNA 4 CYL. DIESEL BU32,36,62 3.4L 1972-92 PO100 Z9
TOYOTA DYNA 4 CYL. DIESEL BU100R 3.4L 1995-01 PO100 Z9
TOYOTA DYNA 4 CYL. DIESEL BU66 3.7L 1988-95 PO100 Z9
TOYOTA DYNA ALL PETROL F6000 Petrol 1968-74 PO100 Z9
TOYOTA HIACE DIESEL Hiace w/ L Eng' 2.2L 1980-82 PO100 Z9
TOYOTA HIACE DIESEL Hiace w/ L Eng' 2.2L 1983-8/85 PO100 Z9
TOYOTA HIACE DIESEL Hiace w/ 2L Eng' 2.4L 9/85-89 PO100 Z9
TOYOTA HIACE DIESEL Hiace w/ 3L Eng' 2.8L 1989-00 PO100 Z9
TOYOTA HILUX DIESEL Hilux w/ L Eng' 2.2L 1980-8/85 PO100 Z9
TOYOTA HILUX DIESEL Hilux w/ L Eng' 2.2L 9/85-1988 PO100 Z9
TOYOTA HILUX DIESEL Hilux w/ 2L & 3L Eng' 2.4 & 2.8L 1988-97 PO100 Z9
TOYOTA HILUX DIESEL Hilux w/ 5L Eng' (Jap.) 3.0L 1998-8/99 PO100 Z9
TOYOTA HILUX DIESEL Hilux w/ 5L Eng'(Thai.) 3.0L 8/99-on PO100 Z9
TOYOTA HILUX DIESEL Hilux w/ 1KZTE Eng' 5LE 3.0L Turbo 2000 ON PO100 Z9
TOYOTA HILUX SURF DIESEL Hilux Surf w/ 2LT Eng' 2.4L Turbo 1984-89 PO100 Z9
TOYOTA HILUX SURF DIESEL 4 RUNNER SR5 DIESEL 2.4/2.8L 1985-96 PO100 Z9
TOYOTA LANDCRUISER DIESEL BJ40,42,70,73 3.0 & 3.4L 1978-90 PO100 Z9
TOYOTA LANDCRUISER DIESEL BJ74 3.4L Turbo 1986-90 PO100 Z9
TOYOTA LANDCRUISER PETROL FJ40,45,55 3.9L 1968-75 PO100 Z9
TOYOTA LANDCRUISER PETROL FJ40,45,55 4.2L 1975-81 PO100 Z9
TOYOTA LANDCRUISER PETROL FJ60,62,70,73,75,80 4.0L 1981-90 PO100 Z9
TOYOTA LANDCRUISER PETROL FJ60,62,70,73,75,80 4.0L 1990-92 PO100 Z9
TOYOTA LANDCRUISER PETROL FJ81 4.0L EFII 1990-94 PO100 Z9
TOYOTA LANDCRUISER PETROL FZJ70,75,80 4.5L 1992-96 PO100 Z9
TOYOTA Stout, RK100, RK101 1970-77 PO100 Z9
TOYOTA Toyoace & 25 All Petrol 1973-86 PO100 Z9
TOYOTA Toyoace All Diesel 1982-86 PO100 Z9
Beno,
Any thoughts on the correct air and fuel filter from Toyota? The one in my truck is a Mann 16136. The fuel filter is coded 23303-64010. Can I order all of these from your parts department with 2 day delivery? I also need a timing belt kit for the same vehicle.
Cheers,
Rich
Beno,
Cheers,
Rich
Rich: please drop me a PM with your model designation from your build plate on your rig or from your frame. :)
