Short in a relay???
I have a 1991 FJ80 landcruiser with what I believe is a short somewhere. After leaving the car parked fully charged for a week, the battery is totally dead. Also, when I brought it in for alternator / batter diagnostics at Autozone, the machine said the test was "inconclusive" and to check the connection to the alternator. The alternator is a toyota OEM and is approximately 1 year old. The test showed a maximum of 30 amps at approximately 2000 RPM
There are 3 wires on the positive battery cable (main power cable to the starter and 2 smaller cables. I disconnected the bolt and removed the 3 wires. The main cable produces no sparks when striking it against the positive bolt. The smaller cable (wire) produces a tiny spark when striking. The larger cable produces a bigger spark when striking, and I also noticed a clicking sound (I believe coming somewhere deep inside the dash?).
One by one, I removed each fuse and relay (under the hood and in the front panel) and struck the wires against the post, and the same amount of sparks and the mysterious relay clicking resulted each time. It seems that removing all of the fuses and relays had no effect on isolating the circuit in question.
Has anyone experienced anything like this? Is this clicking relay normal? Is there another circuit I could be checking?
Thanks for your feedback - tom
Short in a relay???
