Shim?
North Florida
I have a BDS 2.5 lift. One of my projects this winter is taller anti-inversion shackles. I think I will do 3 inch. Do i need to shim my axle?
When I put on my HFS lift a few weeks ago, I also put on 1.5" longer than stock shackles on. I put on 2-degree shims at the same time and later had it checked at an alignment shop. With this combination it was pretty much right on. So for you I would guess 4-degree.
Since you don't have to remove axle from springs to put on new shackles, I would go with 60wag's suggestion and take it to an alignment shop to find out how much shim you need.
