Did some dumb stuff, fiddled around with an aftermarket shift plate and messing with wires with the negative terminal still attached to battery.
Original Problem: 02 LX470 wouldn't shift out of Park unless Shift-Lock was depressed.
2nd Problem: Couldn't get my key out of the ignition unless I pulled the negative terminal off the battery.
Current Problem:
Replaced:
1) key interlock solenoid,
2) shift interlock solenoid,
3) shift lock ECU/controller.
Now I can shift out of Park without issues. Still can't get the key out of ignition unless I pop the negative terminal off OR disconnect the key interlock solenoid.
- LX shifts out of Park with NO key in the ignition. There's nothing that is preventing shifting freely right now.
- LX starts as normal with key interlock solenoid disconnected or connected. Can drive around, reverse, whatever. However, to remove the key when I get back home, I need to disconnect the key interlock solenoid (or negative terminal off battery).
- Tail light fuses are fine with visual inspection.
- Shift Knob slightly loosened based on advice on a Facebook group but didn't fix anything.
- The only used part was the key interlock solenoid.
- The only thing with the new shift lock ECU I bought, was that I needed to do was depin the connectors for the overdrive and green light for the shift plate area and repin them into the new ECU connector.
If anyone has any thoughts, that would HELP a ton!
Current Problem:
Replaced:
