Please explain this to me. I am considering HFS springs and shackles. They told me I should do a shackle reversal to take away a rocking motion. I am totally confused on this and have been trying to do a search without any luck thus far. How much are reversed shackles and where should I get them from?
Just did a shackle reversal on my 40 and I love It. The roads around here can be very dangerous. Prior to the reversal I was getting a rough ride and a lot of bump steer. Big improvment! I do have stock springs and soa. Check out this link.
You don't need a shackle reversal to run *any* springs, let alone the "HFS" springs from CCOT.
The only advantage of a shackle reversal, IMHO, is approach angle, and this is only if a custom low-profile SR is done. And, yes, the front drive shaft may need to be modified.
I was under the impression that a shackle reversal not only helps the approach angle,but bump steer and as the spring is compressed helps the pinion angle as well But I could be wrong it has happened before.
A SR has nothing to do with ride quality. Most of the people that claim significant differences are noticing new bushings and tighter components.. Not something fundamental to the SR..
I can give you a better approach angle (if it is a low profile SR) and it does tend to make a long travel Drive shaft necessary (not always but very common)
I've had it both ways. Still do. I would not do this again. You just don't need it.
For a pure rock crawler, it does give a better approach angle with custom mounts. Still, it introduces a bunch of other issues, like a long travel front shaft, new steering components, etc. It also alters caster, so you need to consider that, and correct appropriately. If I was going to do it with a spring undertruck , I would use the MAF brackets.
Seriously though, yes it improves your aproach angle and supposedly makes them ride/handle better, but better than what? these things aint Caddies boys!
Another thing to consider, the most amount of stress on the frame is on the solid end of the spring, thats why the factory puts the solid ends in the middle of the car, where the frame is stronger. If you do an SR, you should at least box in the front of the frame. Just sayin...............
Bump steer is caused by a high angle on the drag link between the Pitman arm (or center arm) and the steering arm on the passenger side knuckle. As the springs compress and extend, the drag link makes the knuckle turn right and left without moving the Pitman arm. The bump steer effect is minimal when the drag link is parallel to the tie rod. If anything a SR would increase bump steer if it lifts the vehicle so that the drag link angle is increased.
