Serpentine Belt noise
Is our belt the only one squeaky?? When you start it up the noise is bad for about one minute. Belt dressing will quiet it for a few days.
Its a Toyota belt with about 50,000 miles and has been doing this for about 40,000 miles or three years
Any ideas?
Thanks, Dan
Replace the belt? Was this belt a Toyota OEM s-belt?
Was it OEM Toyota or OEM Lexus? Apparently, they are different.
Really!? Not that I need to know...but wonder what/why the difference?
Yep, it helps for a few days only. And then that dressing slightly penetrates to belt material, gets sticky and collecting even more dirt.
Finally, once using belt dressing, permanently damage the belt.
Squeaky belt - is dirty belt. $20 - new belt. And clean up pulleys...
That seems strange to me. However the engineers must have had a good reason eh?
99LX engine pulleys narrower than on LC. Don’t know for what reason. My guess – to reduce weight and engine drag?:confused:
I know in some cases they even use lighter then for Toyota bolts with "grounded" heads :eek:.
Can we gather some statistics on belt widths? Everyone go and measure your belt and report the width in millimeters, the year of vehicle, and whether it's a LC or LX.
Ok.
I have a good friend that works at a toyota/lexus dealer in Mobile Al. I will call him and see if the part numbers are different.
Dan
I talked with toy/lex and the part numbers are the same between the two. Their was a part number revision but it applied to both trucks.
Dan
You going same way like I did: Idea to save $ on Toyota shop versus Lexus, then they told me it is same number like Lexus.
I found that it is different just when removed old one.
Then went to Lex. dealer, got right one and return prev. back to Toyota.
If that will help for reference I just measured it on my 99LX: 21mm
'03 LX, 21mm, OEM lexus belt.
Serpintine
Digging up an ancient post...
I have a 97 LC that has an incredibly squeeky s-belt. I have done the NAPA belt dressing trick...works for a day or two. How difficult is it to relace? I am pretty handy (pulled the radiaitor once...replaced the inner seal in the front end, etc.), but don't want to start anything that is a real PITA.
Thanks,
Dave Brooks
San Diego
^^^ '97 model year LC, North American anyway ;), should be an 80-Series therefore a V-belt.
^^^ I've replaced alot of V belts on different rigs over the years but never owned/done them on an 80-Series. The others weren't more than 1/2 :banana:. If you truly have an 80-Series I'd recommend you post your question in the 80-Series forum...for a little faster answer.
If you have a 100-Series with the V8 then it has a serpentine belt. And this is also a 1/2...er maybe a 1/4 :banana: job to replace.
