While attempting to jump start my FJ80, I smoked the wires shown in the 2nd attached picture.
The part in question is Denso 067d which I believe is the ignition coil:
Prior to smoking the wires, everything on the truck was working as it should.
After getting the truck started the truck had, 2 parts that failed to operate - they are the:
Questions:
Prior to this setback, I was gearing up to make a trip from New Orleans towards the areas of Colorado, Utah, Arizona - I surely do not want this issue to present a failure while on the road.
Any help or ideas as to how to fix the problem would be appreciated.
- the wires leading to the unit were charred during the jumping process
- the wires coming out of the unit look normal
- A/C compressor - it won't turn on. The fan blows but the compressor doesn't kick on when the A/C button is pushed.
- Alternator - 2 separate shops said that the alternator is bad. The truck starts normally and the battery seems to be keeping a normal charge.
Questions:
- Could the A/C compressor and alternator malfunctions be due to smoking the wires running to the part shown (Denso 067d) in the attached photos?
- Could replacing the wires running to the ignition coil be a sufficient fix? Can that single 2 wire piece be sourced by itself?
- Should the coil be swapped for new?
- Does anyone have a reliable supplier that these specific replacement parts can be found?
- Is it likely that the internals of ignition coil was damaged? The truck has zero problems starting, idling or accelerating.
