- Year
- 1999
- Vehicle Model
- LX470
- Mileage
- 245000
- Color
- gold
I'm looking to pass along the LX to a new owner. It's been a solid truck but my needs are changing and I need something with a bit more towing capacity. Below is the maintenance history since I've owned it. prior to that I don't know much other than it's been a Washington vehicle since new. Timing belt and water pump were changed at 180k based on note under hood. Here's a link to a photo album. 99 LX470
- Third row seats and running boards are gone.
- Windshield has crack that's been there as long as I've been the owner
- AC needs a re-charge
- replaced LX climate control with LC manual unit but retained fancy stereo, not a perfect (had to trim bezel) install but all works
- passenger rear window will automatically go back down if you try and close it... but if you hit the window lock button while it's up it will stay
- sunroof inoperable
date | action taken | milage | notes |
10/30/18 | purchased | 230001 | oil, oil filter, air filter |
10/30/18 | AHS delete | 231000 | installed OME rear coils, OME shocks x4 |
10/30/18 | replaced valve cover gaskets | ||
3/13/19 | replaced fender,added snorkel | ||
4/22/19 | replaced corner marker housings | ||
5/8/19 | oil change | 235054 | WIX filter 51348XP, O'reilly 5w30 synthetic |
9/1/19 | front suspension | 238000 | OME torsion bars installed |
9/15/19 | ignition system | 238615 | denso coils, plugs |
02/01/20 | front brake pads | Bosch BC773 front | |
4/1/20 | rear brake pads | 241591 | Bosch BC772 rear |
4/1/20 | front axles and boots | 241591 | replaced front axles, boots, brake pads |
alignment | Les Schwab | ||
5/13/20 | oil change | 242002 | Mobil 1 5w30, NAPA Platinum filter |
