SOLD Seattle: 2002 LX470 174k Miles
Year
2002
  1. LX470
Array
Mileage
174300
Color
rgb(9, 9, 9)
PENDING SALE: Up for sale is my 2002 LX470. $24,995
I purchased about 10 months ago from my neighbor and did a mild restoration on it. All of the detailed information can be found in my build thread linked HERE.
Items I've replace: I may be missing a couple small things
water pump, timing belt, ALL pulleys/idlers, plugs, coil packs, radiator, radiator shroud, Toyota coolant, accessory belt, all small water hoses and heater T's. Valve cover gaskets, fuel filter, hood shocks, Alternator, power steering pump with new hoses and various vacuum lines replaced as needed. All fluids changed minus transmission.
Slee off-road battery tray and terminals
Odyssey group 31 battery
3” dobinsons IMS lift with 167 springs in rear
Old man emu tortion bars
DELTA Panhard Drop Bracket
All new brakes lines (all 6)
New calipers, rotors and Hawk heavy duty pads.
Blackhawk Upper control arms
Method 705 wheels
35 x 10.5 x 17 Kenda Klevers
AHC Delete (zero codes)
New rear upper and lower control arms
Timbren bump stops front and rear with dual up front
Trail Taylor sway bar extensions front and rear
Every suspension component replaced on front end
Inner and outer tie rod ends
OE half shafts
Front Wheel bearings serviced (all new bearings and grease)
Alignment completed by TruLine in seattle
Interior:
New carpet throughout
New driver and passenger seat foam
Professionally installed Ridies leather
Manual climate control swap ( Going to be done in the next two weeks )
All of this has been replaced in the last 1000 or so miles.
Sunroof functions as it should.
$25,995
VIN# JTJHT00W423513023
Ill get more pics of the interior in a couple days.
Please call or text you're interested 4254360007
