Seat Heater Control Dial Switch Bulb Replacement (1 Viewer)
Denver
One of the seat heater control dial bulbs on my 470 has burnt out. Any other 120 series owners out there attempted to replace the bulb behind the control dial so it will once again illuminate when headlamps come on? Found a 100 series thread that says you can just pop out the control dial and slip in a new LED. Before I try prying out the control dial I wanted to see if any fellow 120 owners have done this. If so, do you happen to know the size bulb you used? Thanks in advance!
They are T3. Mirror switch is T4
Thanks Vlad! Do the control switches just pull straight out of the center console or did you need to disassemble the console to get to the switch?
You should be able to pop them up.
