OK, I have used the search option, and read a ton of threads about what I "think" I need to do.
Here is the situation: I have a 1987 FJ60 that we just did a OME medium Dakar suspension kit on (tires are 33/10.5/15). I was told that it would be about 2 1/2 inches taller than stock, but the suspension on the vehicle was so worn out that when measured before and after, it was over 5 inches (not a problem). The front now sits lower than the rear (i here this is normal but I don't like it, so in my book it is a problem). It also now likes to wander a bit at freeway speeds (problem #2).
I read in one post that I need a 4 degree shim on the front to get rid of the freeway wandering, that would be great! Could someone please confirm or deny this for me?
If that fixes that problem, I am left with just one. Can I just put longer shackles up front to raise the front end? If I do this, what sort of negative affect will I see with daily driving (did I forget to mention that this is also a daily driver?)
Any and all help with these matters would be greatly appreciated!
p.s. - this may be a stupid question (i am full of them), but could someone please tell me the difference between a full floating axle and a semi floating axle? I really should know this by now, but I don't. Thanks again.
All front axles are full floaters, rears aren't as common.
